Αναζήτηση στην υποστήριξη
Προσοχή στις απάτες! Δεν θα σας ζητήσουμε ποτέ να καλέσετε ή να στείλετε μήνυμα σε κάποιον αριθμό τηλεφώνου ή να μοιραστείτε προσωπικά δεδομένα. Αναφέρετε τυχόν ύποπτη δραστηριότητα μέσω της επιλογής «Αναφορά κατάχρησης».
Μάθετε περισσότερα
Αυτό το νήμα αρχειοθετήθηκε. Κάντε νέα ερώτηση αν χρειάζεστε βοήθεια.
ERROR MESSAGE ON ALL 3 EMAILS
  • 1 απάντηση
  • 2 έχουν αυτό το πρόβλημα
  • 10 προβολές
  • Τελευταία απάντηση από Carl1959
This is the message I receive when trying to download new messages from all three email accounts. They are all set up crrectly and i have been downloading from these 2 servers (2 of the email addresses are comcast.net) for many years. This problem just started yesterday. Here is the error message: "The account lorienf@peak.org is being processed. Please wait until processing is complete to get messages."
Όλες οι απαντήσεις (1)
First check that you can log into each account with your web browser and view e-mails. Then, assuming these are all IMAP accounts and further assuming none of the accounts are att.net or bellsouth.net, you can delete the accounts and re-add them. With IMAP accounts no e-mail will be lost. (Unless the issue is with your ISP, which while not unheard of, is rather rare.) I've experienced where comcast makes a change to something and it effectively "breaks" thunderbird. But when I delete and re-add the account in Thunderbird, everything works fine. Finally, make certain you are using the latest version of TB also. In the past comcast has made changes that a version of TB could not deal with. Then, when I upgraded to the latest, everything worked just fine.
